starter problem ....
Old Feb 9, 2009 | 05:44 PM
ghost stripes's Avatar
first off my car wouldnt crank the other night and the dash was dead ...i posted on here was told the ignition switch needed to be replaced so i did that and now the dash works but when i went to turn it over the starter bumped and the dash went dead again the switch work 3 minutes and then died .....is it possible that the starter is burning up the ignition switch ...should i replace the solenoid ...any advice will be appreciated
Old Feb 9, 2009 | 08:28 PM
RamAir95TA's Avatar
Have you ruled out a weak/dead battery?
Old Feb 9, 2009 | 08:39 PM
Drew24's Avatar
if i were you i would start small like the battery connection might be loose or corroded and or battery might be dead
Old Feb 9, 2009 | 10:03 PM
i will replace the battery tommorow and repost i will try anything at this point
Old Feb 9, 2009 | 10:09 PM
jtarp's Avatar
I wouldn't replace the battery if you don't know if it's dead. I would go get it tested before you decide whether to replace it or not.
Old Feb 10, 2009 | 10:39 AM
Drew24's Avatar
I agree make sure the battery is bad before you replace it if its not broke dont fix it you can take it down to like autozone and get it tested for free
Old Feb 10, 2009 | 11:07 AM
ok i will do that...
AlaskaZ28
Apr 17, 2015 08:54 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Jeff1904
Jan 3, 2015 12:00 AM
