Starter keeps cranking when battering is connected (key not turned)
Old Jul 14, 2009 | 06:47 PM
  #16
Originally Posted by Angelis83LT
No... You tested the circuit within the starter itself. I believe it is always closed, I could be wrong though. One wire is a the hotlead, and the other is a ground wire. when the ground wire is grounded the motor turns. the action of turning the key is what grounds it I would guess. therefor if that is true, then one would think that the there is not an open circuit within the motor? I should get the book out on how they are assembled. Heck. You Could have a short within your ignition switch, which lets the motor start by itself because the ignition switch is shorting.
In fact, a shorting ignition switch would make a whole lot of sense if it is happening with more than one starter.
No, the smaller purple wire is not a ground. It is 12v power when the ignition switch is turned to START. Ground is provided by the mounting/bolts.
What the OP previously posted it that is cranked by itself with no wire on the smaller lug, so it can't be the ignition switch.
Old Jul 14, 2009 | 07:25 PM
  #17
matLT1's Avatar
UPDATE: Think the cause of the issue was the positive lead contacting the small post. The tab on the positive lead that is supposed to be bent at a 90* angle was at ~45* and allowing the positive wire to turn and bump into the smaller post. Read resistance between positive post and small post and it indicated 0.3 ohms. To me this indicates a fryed solenoid due to high voltage going through it.
eazyZ
Mar 1, 2015 07:12 AM
cyteone
Feb 7, 2015 06:04 PM
Dzmaro
Jan 25, 2015 10:39 AM
formula79
26
Aug 5, 2002 12:21 PM
