Starter gone"?
Old Oct 6, 2004 | 01:44 PM
9T4Z28's Avatar
Starter gone"?
last week the car would start to crank over and then a "miss" like you would hear a winding down noise, and then today after filling the gas up i go to start and it wouldnt start i must have turned the key about ten times then it started. Is my starter gone?
Old Oct 6, 2004 | 08:17 PM
Guest47904's Avatar
Guest
Re: Starter gone"?
You need to check the teeth on the starter gear and the flywheel before you go jumping to replacing things.
Old Oct 6, 2004 | 11:20 PM
9T4Z28's Avatar
Re: Starter gone"?
If the teeth are broken on either how much would it cost for the parts?
Old Oct 7, 2004 | 12:30 AM
indieaz's Avatar
Re: Starter gone"?
depends if you got broken teeth on the starter or flexplate. Flexplate teeth being broke are pretty unlikely so a new starter is gunna run you around $140-$160 depending where you go. If it really is broken teeth on the flexplate then you're gunna have to pull the tranny off to get the flexplate off. Not fun
Old Oct 7, 2004 | 12:33 AM
Donohue96M6Z28's Avatar
Re: Starter gone"?
if the starter is bad, id just get it rebuilt, i got mine rebuilt for $55
Formula Steve
Sep 19, 2023 08:31 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
4586
Aug 18, 2015 07:08 AM
realistyc
Jul 28, 2015 07:32 PM
