Best header gaskets
Old Oct 5, 2004 | 04:36 PM
Mtdewandal's Avatar
Best header gaskets
Could someone please tell me the best header gaskets to use and best place to buy them? Thanks for and input.
Old Oct 5, 2004 | 04:41 PM
95_LT1_6SPD's Avatar
Re: Best header gaskets
i use mr.gasket paper gaskets. The cheapest and have yet to fail me.
Old Oct 5, 2004 | 04:50 PM
joebeemish's Avatar
Don't forget to use locking bolts - I discovered the hard way that if you use bolts that do not lock, they will back out from vibration and heat and you get a blown gasket. They also are very difficult to get a socket or wrench on. I just got stage 8 bolts and will be installing them shortly.
Old Oct 5, 2004 | 06:18 PM
FlyboyZ28's Avatar
stock replacment metal gaskets and stage 8 bolts for me...no leaks.
Old Oct 6, 2004 | 08:34 AM
stereomandan's Avatar
You'll get all sorts of answers, but in my experience, get the Felpro 1406's or Mr Gasket Ultraseals. They are both very similar in construction and work great. The factory metal gaskets are nice too. I had bad luck with copper gaskets.
You do not need locking bolts. You just need to make sure that you retighten the bolts every once in a while for the first few weeks. They will stay locked after a little while. The stage 8 bolts can be very hard to work with. The Breslin splitlocks seem a better design, but I don't think you need locking bolts at all.
Dan
Old Oct 6, 2004 | 08:38 AM
WS Sick's Avatar
I have never had a problem with Fel-Pros or Mr Gasket Ultra Seals.
Old Oct 6, 2004 | 08:51 AM
zhevy-1's Avatar
GM stock gaskets. I've tried to be cute before with all sorts of different header gaskets. Believe me, I've tried a few in the last 5 years. So far, my best combo has been GM gaskets, and locking header bolts. No leak, and those suckers just don't burn.
Old Oct 6, 2004 | 10:13 PM
Bud M's Avatar
Earl's gaskets from Summit Racing and Stage 8s have worked great for me.
Old Oct 7, 2004 | 12:06 AM
TigerWoodsJr's Avatar
another vote for felpro.
Old Oct 7, 2004 | 12:50 AM
S8ER95Z's Avatar
Felpro here.
Midnight_Z
Feb 16, 2016 09:36 PM
dylan1303
May 22, 2015 12:24 PM
4586
Apr 29, 2015 01:43 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
