Starter dead?
Most definitely. Turn on your head lights. If they work fine, then your ground is ok. But if your ground is loose, or you have corrosion on the either of the terminals, somethimes you might have enough power to turn lights on, but not enough to start the engine.
If your battery age is close to, or expired, its time to get another one, because those dates are fairly accurate.JMHO
Formula Steve
Sep 19, 2023 08:31 AM
jackpawt883
Sep 10, 2015 08:53 PM
