Starter Clicks But No Start, Any Ideas?
Old Jun 24, 2003 | 07:27 AM
Rico's Avatar
I went to start it up and the thing clicks but no start, I was driving the car fine yesterday, I'm so not use to hearing a click and no start it's usually the other way round when the solinoid thingy dies.
And yes the battery is fine.
Do the motors just die or what? I guess they would eh!
....Rich
Old Jun 24, 2003 | 07:35 AM
96z's Avatar
96z
Hmm take it off and to autozone or something similar to see if it checks out alright.
Old Jun 24, 2003 | 07:38 AM
Rico's Avatar
I was thinking of that, it sounds weird thow.
...Rich
Old Jun 24, 2003 | 07:44 AM
It would be nice to have a remote starter switch. You clip it onto the purple wire terminal and the battery cable terminal at the starter. If it won't crank when you engage the remote switch, the starter is bad (if battery cable and battery are good). You can do the same thing with an old screwdriver (shorting across the terminals) or a heavy gauge wire, but it is a little "messy".
Did you check your connections at the battery and the starter?
Old Jun 24, 2003 | 07:50 AM
Rico's Avatar
Yah, I checked everything.
Well I will take it over to a shop and have them look at it.
...Rich
Old Jun 24, 2003 | 09:11 AM
94 NO TOP Z's Avatar
95% of the time that is the battery or loose connections. Have your battery tested at a local store.
Old Jun 24, 2003 | 09:13 AM
hairbear21's Avatar
If it's not the solenoid, it can be the starter. The clutch discs in the starter can go out and it will not engage like it's supposed to (trust me, I know this because I have experienced it, and I did a ton of research on it)
Old Jun 24, 2003 | 12:21 PM
JoshGuitar's Avatar
I just had an identical problem on my old dodge truck. The starter solenoid clicked but the starter didn't crank. Possible causes in the haynes manual were bad battery, bad connections, or bad starter motor. Voltage on the battery was fine, but just for the hell of it I tried jumping it with my other truck, didn't work...I was down to bad connections or bad starter...I pulled the starter, connected jumper cables directly from the battery to the solenoid and starter terminals, same thing, solenoid clicked, starter didn't spin...I took it to autozone, they confirmed that the starter was toast, and 80 bucks and 20 minutes later the truck was running. If your battery is good, prolly do the same...pull the starter, check it with the battery and jumper cables first, or just take it straight to autozone or advance or whatever, they'll test it for ya.
Oh, the last possible cause they listed was that the engine was seized or hydrolocked...wasn't that, thank god
Old Jun 24, 2003 | 12:44 PM
mc63's Avatar
I just experienced the same thing, but it was the opposite of the post just above!!!
Mine would do nothing but click... I too thought it was the starter.
I pulled it, took it to AutoZone, it tested fine.
Turns out it was the battery!!!
Boy was I happy
Starter- $174.00
Battery- $64.00
Pull the battery and have it tested first. Even if you check it with a meter and it shows 12 volts, that does not mean it does not have a bad cell.
Old Jun 24, 2003 | 12:50 PM
Bralgar's Avatar
I have this problem with my car but it isa intermittent. One time it will start as normal, the next time I try it will just click. I can turn the key back and forth a few times and the engine will finally turn over. Battery is good. I thought maybe it was the vats and my key was dirty. Guess I better think about swapping out the starter from my spare engine before I get stranded.
HCz28
Jan 11, 2015 11:21 AM
HuJass
Aug 29, 2002 02:30 AM
HuJass
Aug 27, 2002 09:58 PM
HuJass
Aug 27, 2002 09:53 PM
HuJass
Jun 27, 2002 11:04 PM
