starter??
Old Feb 16, 2006 | 01:54 PM
EVERESTZ28's Avatar
starter??
since my engine rebuild my starter can turn on the engine quickly when cold but once engine it's hot it's more dificult take like 4 sec. the starter was rebuilded recently.
Do you know if exsist a "bolt on" stronger starter or one that needs minor mods to install it?
Old Feb 16, 2006 | 02:49 PM
OBE1 95Z28's Avatar
Re: starter??
Slower starting when warm may be a tuning issue as a warm engine needs a different air/fuel mix than a cold engine.
Old Feb 16, 2006 | 06:12 PM
EVERESTZ28's Avatar
Re: starter??
thanks i never imagine that. i still want to know if a "performance" starter it's available for fbodys?
Old Feb 16, 2006 | 11:26 PM
3gc's Avatar
3gc
Re: starter??
Basically most GM starters for a 168 tooth (someone correct me if i'm wrong about the tooth count) flywheel will bolt up no problem. There's the lt4 starter too that some people put in.
Is it cranking over slowly when it's warm? Maybe it's heat soaked, some people put a heat sheild or a blanket around the starter to deflect radiant heat from the headers. However, I haven't had a problem with my starter yet, and it's original.
Old Feb 17, 2006 | 07:50 AM
Re: starter??
LT1 flywheels have 153 teeth.
Look at Summit or Jegs for high torque starters. The LT4 starter is stronger, as well.
Old Feb 17, 2006 | 10:43 AM
stingercamaro's Avatar
Re: starter??
I put a Powermaster starter on my Formula yesterday. Kinda crappy workmanship, but can't argue with the result.
Old Feb 17, 2006 | 10:46 AM
blkchevyz's Avatar
Re: starter??
yeah thats what i was thinking also.
Old Feb 17, 2006 | 06:38 PM
EVERESTZ28's Avatar
Re: starter??
yes it cranks slow when warm...frist second makes an atempt..2nd second apears it stop..3 and 4 second it turn on the engine.
Formula Steve
Sep 19, 2023 08:31 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
4586
Aug 18, 2015 07:08 AM
realistyc
Jul 28, 2015 07:32 PM
