Starter
Old Nov 20, 2005 | 03:05 PM
Chevrolet Bailey's Avatar
Angry Starter
I have a 94 Z/28 Camaro LT-1 Engine, How hard is it to change the Starter, I washed the engine Saturday i knew better to do that and i guess i burned up the starter cranking trying to get it started you have to keep turning the key like the selnoid is bad and when it kicks in it makes a hell of a noise. just wondering how hard it is to change. Thanks
Old Nov 20, 2005 | 08:02 PM
Guest47904's Avatar
Guest
Re: Starter
Piece of cake. 2 bolts, 2 wires and your there. Still won't fix your other problem though.
Old Nov 20, 2005 | 08:29 PM
Re: Starter
What do you mean it wont fix my other problem
Old Nov 20, 2005 | 09:13 PM
Harvey's Avatar
Thumbs up Re: Starter
Sounds like the optispark to me. Washing the engine is a no no. If you can park the car and wait awhile, look into getting an MSD opti. Their new and on back order, but from what I've heard it doesn't have the design flaws the OEM optispark has plus some extra goodies.
Wayne
Old Nov 21, 2005 | 04:45 AM
Guest47904's Avatar
Guest
Re: Starter
Did I misunderstand you? You washed the engine down. It wouldn't start. Cranked it till it burned up the starter. New starter won't fix the non starting issue. Drying out for a while might.
Old Nov 21, 2005 | 05:45 AM
Re: Starter
No i got the car started after cranking on it for a while but now when i go to start it it acts like the selinoid is not kicking in you hace keep turning the key and when it kicks in and the motor starts turning over it makes a hell of a noise.
Old Nov 21, 2005 | 09:12 PM
Eddie Z-28's Avatar
Re: Starter
Probably snaped the nose off it like I did mine.
Old Nov 21, 2005 | 09:23 PM
aarontracy's Avatar
Re: Starter
to change the starter ur going to have to drop the exhaust also since its a 94 thats the only hard part
Old Nov 21, 2005 | 10:28 PM
cammed_aro Z28's Avatar
Re: Starter
you dont have to drop the exhaust, i did my 94 with everything in place. just disconnect the battery, take the 2 bolts out of the starter and take the torque converter cover off if it is an auto and you kinda have to twist and stand it straight on end pushing toward the front of the car and it will fit thru that hole. it seems like it wont, the first time it takes a little force and trial and error, ( he he he) but the second time is much easier after you find the trick. the second time i did it (on a buddys car) i had it at his feet in ten minutes.
Formula Steve
Sep 19, 2023 08:31 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
4586
Aug 18, 2015 07:08 AM
realistyc
Jul 28, 2015 07:32 PM
