Started on my dual 3" exhaust over the axle.
Ive been working on my exhaust setup all day. Going 3" mandral bent over the axle on the passenger side. At this point I have the exhaust above the axle. I build brakets to relocate the Panhard bar and upper panhard brace. Here is a quick Pic of the exhaust in the driveway. Once I get the car up and running and im sure the exhaust will fit I am going to do some sort of an x-pipe or h-pipe.
Re: Started on my dual 3" exhaust over the axle.
Originally Posted by Loadre
Time to make a jig and become a vendor.
One of my buddies is already telling me his gunna want a set eventually. This takes a lot of time. I dont have a pipe bender so I just bought a bunch of U-bends at the hot rod shot and Im peicing it together. I need to go back tomorrow and get a couple more bends and some muffelers. I think I can fit a chambered muffler. Ill probably pick up a couple flowmaster 40 series tomorrow.
I'm thinking you could make a template and a jig not only to piece it together and weld it, but also showing where to cut each piece.
Stick it in one jig, mark and cut. Stick it in the other jig, tack and weld.
Yours makes mine look like i spend 30 min on it...err well, ahhh i did spend 30 min on it. You've got some talent and patience that i dont have...ill be taking mine to a muffler shop here sometime, im getting sick of the drone.
Originally Posted by 95_MuLLeT_LT1
What would be even better is to put an X-pipe setup in the middle. Would change the sound quite a bit.
