Stange Engine Noise
Old Jul 18, 2009 | 07:18 PM
BlackCamaros's Avatar
Stange Engine Noise
I got home this afternoon and noticed my car making this weird engine noise. It kind of sounds like a bad bearing but it sounds like it is coming from under the intake. Could this be a bad lifter? ? ?
The engine is stock, with 130K miles.
Video of the car running
http://rides.webshots.com/video/3016...27582097GtJLip
or
http://s968.photobucket.com/albums/a...inenoise_1.flv
Last edited by BlackCamaros; Jul 18, 2009 at 08:16 PM. Reason: link wasn't working
Old Jul 18, 2009 | 07:46 PM
n2ceptor's Avatar
We're sorry...
...due to a high volume of page requests, this Webshots page is not available right now.
If you are looking for a photo, it is possible that the photo has moved or no longer exists.
If you are in the process of creating an album, please be assured that your data has been sent to our site. You may try refreshing the browser window or reloading the page in a few moments.
Old Jul 18, 2009 | 08:10 PM
Not sure why that message. I got it too, but tried later and it was fine. Try this link:
Old Jul 28, 2009 | 07:27 PM
topcat64504's Avatar
Hi, I'm brand new to this forum. I ran across your problem as I was searching for anyone who may have experienced similar problem with my 1992 vette. New car to me and recently developed noise just like yours. I am suspecting waterpump drive, as sound eminates directly from rear of waterpump. Have had no time to investigate, but will keep watching for any help. thank you.
Old Jul 28, 2009 | 07:31 PM
n2ceptor's Avatar
I forgot about this thread.... But it sounds like a air pump leak, maybe????
Old Jul 29, 2009 | 03:12 PM
It turned out to be the rubber elbow that connects to the PCV valve. The rubber was really soft, and had expanded so the fit was very loose. I zip tied it around the nipple on the PCV and the noise was gone. Two days later on my way to the parts store, it starts making the noise again. I pop the hood at the store and find the boot seperated right where I put the zip tie. The rubber was very soft and just tore. I replaced it with something they had in house, and so far it's been good. I'm not sure why the rubber softened, as I haven't sprayed anything on the motor in months.
Old Aug 31, 2009 | 08:31 PM
strange engine noise solved
My strange knocking noise in my 92 LT1 turned out to be the harmonic balancer pulley. Had 2 bolts missing and 1 very loose. Suspect that previous owner had distributor problems and did not use locktight in bolts.
All better now. Thank you
Fatdog2
Feb 12, 2015 12:24 PM
ro2207
Dec 4, 2014 06:18 PM
squarehead
Nov 21, 2014 08:02 PM
johnsocal
77
Sep 16, 2002 03:31 PM
Omega9
Aug 2, 2002 12:33 AM
