Standard volume vs. 10% volume on LT1 oil pumps.
Having trouble finding the right oil pump for my forged 355 LE2.
I dont want the Melling M55a due to the thin casting failures I have been reading about. I will be running the stock LT1 oil pan.
That leaves the Melling select:
10554 STD volume oil pump
10552 10% boost in volume oil pump
Can I run the 10% higher volume oil pump without having the pan sucked dry issues or should I stay at the STD volume. I think the majority of the problems have been from the 25% oil pumps.
What do you guys think about these two pumps.
So the question is will there be any pan dry issues with the 10% over standard oil pressure. Brett responded to the other and said no, however I want to hear from those that might be running this pump.
My new shortblock has .0022" - .0025" on the rods and mains. I am still trying to make the best decision to get the best oil pump for my 355 LE2. The choice is stock volume or 10% extra on the pump volume.
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
Jul 4, 2005 05:00 PM
guionM
9
Aug 29, 2002 01:48 PM
