Standard volume vs. 10% volume on LT1 oil pumps.
Old Feb 9, 2007 | 10:13 AM
wrd1972's Avatar
Having trouble finding the right oil pump for my forged 355 LE2.
I dont want the Melling M55a due to the thin casting failures I have been reading about. I will be running the stock LT1 oil pan.
That leaves the Melling select:
10554 STD volume oil pump
10552 10% boost in volume oil pump
Can I run the 10% higher volume oil pump without having the pan sucked dry issues or should I stay at the STD volume. I think the majority of the problems have been from the 25% oil pumps.
What do you guys think about these two pumps.
Old Feb 9, 2007 | 10:33 AM
Colin91Z's Avatar
What happen to your other thread?
Old Feb 9, 2007 | 10:37 AM
wrd1972's Avatar
I was commenting on the wrong pumps, those were 5/8 pickups.
I need the 3/4 pickup, it was deleted to reduce confusion.
Old Feb 9, 2007 | 11:00 AM
seawolf06's Avatar
I would go with the 10552 or 10552C if I didn't already have the M55A. I think the extra volume is great and won't suck the pan dry. Looks like the pickup bolts on as well.
Old Feb 9, 2007 | 11:38 AM
Colin91Z's Avatar
Oh I see, so the part #s at in your first post in this thread are 3/4 inlet then?
Old Feb 9, 2007 | 11:49 AM
wrd1972's Avatar
Yes,
So the question is will there be any pan dry issues with the 10% over standard oil pressure. Brett responded to the other and said no, however I want to hear from those that might be running this pump.
Old Feb 9, 2007 | 01:15 PM
gex598's Avatar
I have a 10552 with stockish pan. I spin to 7k at the track and have not sucked the pan dry. Make sure you loctite the bolts on the pickup, I had mine fall off!
Old Feb 9, 2007 | 01:16 PM
seawolf06's Avatar
Tac welding is not a bad idea either.
Old Feb 19, 2007 | 10:41 PM
sam pace's Avatar
what sump screen did you use?
Old Apr 11, 2007 | 06:03 PM
snakeatinZ's Avatar
Old Apr 12, 2007 | 08:08 PM
wrd1972's Avatar
What bearing clearances do you run.
My new shortblock has .0022" - .0025" on the rods and mains. I am still trying to make the best decision to get the best oil pump for my 355 LE2. The choice is stock volume or 10% extra on the pump volume.
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
Jul 4, 2005 05:00 PM
guionM
9
Aug 29, 2002 01:48 PM
