Stalls in Reverse
Old Sep 7, 2009 | 07:03 PM
SmokeyBlaZe's Avatar
Stalls in Reverse
What can I do to keep the car from stalling out in Reverse?
Old Sep 7, 2009 | 07:43 PM
z0s0's Avatar
Don't use reverse. Sorry man, couldn't resist...
Old Sep 7, 2009 | 11:05 PM
Fix the IAC valve.
Old Sep 8, 2009 | 12:45 AM
Originally Posted by Injuneer
Fix the IAC valve.
I know it has already been cleaned , but I will try to reset it and see if that works.
Old Sep 8, 2009 | 01:17 PM
WS6T3RROR's Avatar
Put a stall in it and it will quit doing that. Your other option is to bump the park idle rpm a couple hundred above the in gear idle rpm. There are other things that can be done too but they are all in the tune. Kind of need a datalog and a copy of the 'custom tune' to figure out what needs to be done to help it. Its still going to stumble badly into gear without a stall in it but at least it wont die with a few tricks working. If you don't have the stuff to log or tune, you can try cracking the throttle blades a little bit more.
Old Sep 8, 2009 | 02:14 PM
That was my first thought, so I posted this
Originally Posted by SmokeyBlaZe
would a stall converter keep the car from cutting off when i put it in reverse?
Originally Posted by MarcR94v6
I don't understand what you're asking, what do you mean "cutting off"? Is your car dieing or stalling when putting it in reverse? If so, that has nothing to do with a stall converter, which is a transmission component.
https://www.camaroz28.com/forums/sho...verter+reverse
Old Sep 8, 2009 | 02:56 PM
WS6T3RROR's Avatar
You believe whoever you want to, i've driven and tuned a few cars with big cams and a stock stall. All that bull**** goes away every time when a proper converter goes in. Although most of the time you can crutch it with some tuning.
If you do it you will want to swap gears too because a decent stall with 2.73 gears is going to suck bad. When the converter isn't locked up around town you will probably be able to change engine rpm by 1000 without changing speed. 3.73's will make a converter feel much tighter and thats what I would go with.
A trick to keep it from stalling is be ready to drive when you fire it up. When you start the car it will rev up a bit and then settle to commanded idle. If you drop it into reverse before it gets the chance to settle most of the time it wont die out.
Old Sep 8, 2009 | 03:21 PM
bw_hunter's Avatar
Read his other post. The engines only running on 4 cylinders. Even a high stall convertor isn't going to fix that...
After he gets it running then a convertor would be a good idea...
Old Sep 8, 2009 | 04:17 PM
WS6T3RROR's Avatar
Guess I assumed he had his **** together and the car was running on all cylinders, shame on me .
Old Sep 9, 2009 | 02:37 PM
Just like that guy assumed I was running on 4 cylinders.
Nayr
Mar 3, 2023 08:34 PM
blac94Z
Nov 4, 2015 01:59 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
damnyankee36
Sep 9, 2015 07:06 PM
