stalling issues, getting bad
Old Feb 6, 2006 | 10:25 PM
dfa_crunch's Avatar
couple weeks ago my car stalled while i was stopped at a stoplight, kinda confused i started it up and went on my way. a day later i was on the highway and when i shifted into 5th gear, i pressed down on the gas and nothing happened, put the clutch down and tried again, when i came out the car shut off, started it back up and went on my way. i replaced the fuel filter and the problem seemed to stop for a few days. the problem came back and it got worse, i noticed that when it is about to stall the rpms go really low when idling, about 800, and my oil pressure drops too. Today was the worse, every time i let off the gas to stop my car, the car shut off, was a hell of a drive getting home. me and my stepfather seem to think its the fuel pump, or maybe a clog in the fuel lines, but i dont want to buy the parts and go into fixing it without knowing its the sure thing.
any thing will help, thanks
Old Feb 6, 2006 | 11:22 PM
MyShibbyZ28's Avatar
Re: stalling issues, getting bad
Buy a fuel pressure gauge and check the pressure. Should be about 45 psi primed, 38 at idle, and 50 at WOT. That will tell you if it is the fuel pump right there.
I've also heard of bad EGR solenoids making cars stall when the gas is not constantly pressed down.
Old Feb 7, 2006 | 12:22 AM
dfa_crunch's Avatar
thanks for the info, im pretty sure my friend told me autozone lets you rent them ill do that
Old Feb 7, 2006 | 09:53 AM
OBE1 95Z28's Avatar
Fuel pressure should be 41 - 47 psi at idle with the vacuum line removed from the fuel pressure regular (simulates WOT).
Old Feb 9, 2006 | 07:42 AM
dfa_crunch's Avatar
i was told to try and change the ignition module
any thoughts?
Old Sep 14, 2006 | 01:20 PM
Bow94z's Avatar
you ever find out the problem?
Old Dec 5, 2006 | 12:40 PM
dfa_crunch's Avatar
in may i brought it to a mechanic. he replaced my air flow meter, intake temp sensor, and oxygen sensor. he also cleared my computer settings
it ran fine until a few weeks ago, the problems back.
im moving the someplace warmer, the car runs fine in the warm weather.
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Amshnock
14
Jan 18, 2015 11:47 AM
David Dorris
Jan 17, 2015 08:10 PM
Jan 5, 2015 07:14 PM
94redform
Sep 8, 2002 03:27 AM
