Stainless header bolts in aluminium heads
Old Jun 19, 2006 | 09:37 AM
xxvann's Avatar
I bought some ARP stainless bolts for my LT1 heads. I've recently heard, however, that stainless doesn't work well with aluminium, that it may corrode either the bolt or the head.
Comments?
Old Jun 19, 2006 | 10:10 AM
1redTA's Avatar
Re: Stainless header bolts in aluminium heads
some anti-seize will be your best friend
Old Jun 19, 2006 | 11:45 AM
Z28SORR's Avatar
Dissimilar metal corrosion can occur any time two different types of metal make contact with the help of a little moisture. Stainless is probably better than, not worse than, other types of metals. Your fasteners have to be made out of something! So I'll take stainless over standard steel any day. Just make sure you use the anti-seize like "redta" said.
Old Jun 19, 2006 | 12:16 PM
ledfootz28's Avatar
i just got some afr 210 alum heads and went with some arp stainless header bolts.im afraid if you put antisieze on them they could eventually back out and may need to be tightened often which is a bitch if you have long tubes.
i just put some low strenght loc tite on them
Old Jun 19, 2006 | 12:21 PM
xxvann's Avatar
So it should be either anti-seize OR loc-tite? I know the benefits of both but need to know for sure which to use.
Thanks!
Old Jun 19, 2006 | 12:31 PM
anaik's Avatar
I used the ARP 1" stainless bolts with anti-seize, and after checking a few times after the header install, found they never loosened up.
Old Jun 19, 2006 | 04:14 PM
Jameslt1TA's Avatar
I wouldn't use loc-tite or anit-seize on header bolts. I just put em in and check them every now and then to make sure there tight.
Roadie
Feb 16, 2015 10:34 AM
rcajun86
Jan 30, 2015 01:56 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
