Stagging.....
Old Dec 18, 2003 | 01:22 AM
Heatmaker's Avatar
Advanced Member
Stagging.....
When I stage my car I can't get her to hold still. Even with the Brakes fully engaged the front end still drags forward. I actually put a tear in my new Nitto from that crap. The rear wheels start spinning...smoking ETC. and the rear sways somewhat. But I don't know why...The rear end is built to hell...And I have Slots with the Carbon Pads...I'm wondering if my Front wheels aren't getting the proper amount of pressure or something I spent 3 weeks redoing the complete brake system....Is that normal behavior??????
Old Dec 18, 2003 | 04:51 AM
97WS6SCharged's Avatar
What size converter are you using?
Old Dec 18, 2003 | 08:41 AM
red's Avatar
red
What RPM's are you bringing the car up to when you stage? Most likely you will need to back off your RPM's.
Old Dec 18, 2003 | 08:43 AM
S.J.S.'s Avatar
just cut the r's a lil and don't deep stage too much. Get on it as the tree drops.
Old Dec 18, 2003 | 09:42 AM
93Z286Speed's Avatar
kinda depends what stall your running too
Old Dec 18, 2003 | 11:02 AM
Heatmaker's Avatar
Advanced Member
It's an M6
Old Dec 18, 2003 | 12:19 PM
1994CamaroZ28's Avatar
How are you really having trouble with the m6 at the line you must be slipping the hell out of your clutch
Old Dec 18, 2003 | 12:35 PM
FyreLance's Avatar
I was kinda thinking that too...
Old Dec 18, 2003 | 03:35 PM
Heatmaker's Avatar
Advanced Member
This was before I swapped the clutch out....But I didn't smell any Clutchage...wouldn't the clutch be making that odar if it was slipping?
Old Dec 18, 2003 | 04:03 PM
red's Avatar
red
You clutch is not fully disengaging.
