Stage 8 Locking Fasteners, what size?
Old Nov 11, 2004 | 08:48 PM
Don't Look Back's Avatar
I'm probably going to put a set of Pacesetter LT's on soon, and I'm trying to figure out the best stuff to get to install them. Although they're a little pricey, I like the peace of mind that will come with the Stage 8 header bolts. Pricing them in Summit I see there's a 3/4" and a 1". Which ones will I need? I also see there's specific ones for the LS1, is there a specific set for the LT1 also, or just regular SBC's?
Thanks,
Keith
Old Nov 11, 2004 | 09:00 PM
Dave88LX's Avatar
Re: Stage 8 Locking Fasteners, what size?
Go with the 1". At least that's what I went with. I screwed them all the way in , and the gap when it bottomed out between the head of the bolt and the head is thinner than the manifold flange thickness.
No specific LT1 set, just SBC.
Old Nov 11, 2004 | 09:02 PM
Dave88LX's Avatar
You may want to give these a look also:
http://www.go-breslin.com/text.html
I think Summit carries them now.
Old Nov 11, 2004 | 09:44 PM
a walker's Avatar
I used the 1" when I installed my Jet Hot long tubes a few months ago. I wish I would have gotten the 3/4". The 1" was just a tad too long to clear one of the primary tubes on the passenger side. I ended up having to write Stage 8, and they sent me a replacement 3/4" no charge overnight Not a big deal, but if I had the 3/4" from the start, I would have been able to finish the job and not have to wait for a new one to come.
My thoughts on the Breslin's? They look great and I'm sure they work well. The problem is that on the LT1, some of the bolts were very hard to get to with a wrench. That's why I got the Stage 8; so I could tighten certain ones with the allen wrench. You couldn't do that with the Breslin's.
Old Nov 11, 2004 | 10:32 PM
atljar's Avatar
The bolts paceSetter sends out are 1 inch, so thats what i would use.
Old Nov 11, 2004 | 10:42 PM
Dave88LX's Avatar
Which tube wouldn't it clear? I just did Jet Hots and the 1" Stage 8's with no problems...the problem you had could most likely been alleviated by pulling the header away from the head, slipping the bolt through the flange, then getting it started before tightening the header down.
Old Nov 11, 2004 | 11:45 PM
a walker's Avatar
It was cyl 4. I tried everything I could to get the 1" started, but eventually used one of the 3/4" Jet Hot provided until the 3/4" from Stage 8 arrived.
Old Nov 12, 2004 | 07:28 PM
Bud M's Avatar
I used the 3/4" bolts no my Hookers.
Old Nov 12, 2004 | 07:58 PM
atljar's Avatar
I used 3/4 on my hookers too. My paceSetters on the other hand used 1 inch, the flange is about 2x as thick.
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
Pampered-Z
Apr 14, 2015 05:38 PM
cyteone
Feb 7, 2015 06:04 PM
