Stage 8 Locking Bolts or ARP Header Bolts?
Old Jun 12, 2003 | 11:27 AM
  #16
revtime's Avatar
I did have the alternator off.
I still can,t get the damn thing on.
Old Sep 18, 2003 | 09:43 AM
  #17
OffspringZ28's Avatar
I have ARP 12pt bolts. Tighten them a couple days after heat cycling and they havent backed out since. Thats been almost 2 years ago. I would buy the ARP's again if i had to do it all over. Oh yea, all the bolts are cake to get to with a small wrench and a little grinding on the closed end of the wrench so it fits between the primary tubes and the bolts. 5mins of grinding the wrench if that.
could you explain in better detail? what makes the ARP's different/better than the bolts that came with the headers? I have Jet-Hots and the thick primaries make it impossible to get anything around the head of the bolts in the back bolts of the pass and driver side. Do the ARP's have smaller heads on em? do you have any pics of em on your car? the only reason i would be looking at stage 8's is because of the the allen head deal. dont really feel like messing with little locks, im fine with just retightening if i have to. The allen head seems like putting the bolts on would be cake.
Old Sep 18, 2003 | 09:46 AM
  #18
got_hp?'s Avatar
stage8 + allen head =sweeeeeeet
its the best way to get all the bolts as tight as possible without slicing off pieces of your arm/hands.
i didnt use all the retainers (they are annoying to put on)
i used 2 or 3 on each side...............but mainly used the stage8s because of the allen head makes it so much easier.
Old Sep 18, 2003 | 11:00 AM
  #19
PoorMan's Avatar
You can sort of see how the ARPs are in this pic. Head smaller to get a socket on. Look at #1.
http://community.webshots.com/photo/...90074977eKDGoN
Jeff D.
Old Sep 18, 2003 | 11:13 AM
  #20
Jason Dove's Avatar
I used the bolts that came with my headers, it's been 3 years and they hadn't backed off at all when the headers came off last week.
Old Sep 18, 2003 | 11:58 AM
  #21
CamaroBoy96Z28's Avatar
I bought the ARPs. I like them but the 4th bolt from the front on the pass side (right after the #6 primary) fell out and the 2nd from the front was very loose on the same side. I already retorqued the driver's side and there's no problems there but I found this yesterday when I went to do the pass side (should of done it earlier). I like the bolts but I didnt retighten them when I should of due to lack of time. So now I'm trying to get a bolt that came with the headers into that hole and its not working out too well from up top. Tomorrow I'm going to try and do it from the bottom.
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
ChrisFrez
Jan 11, 2015 03:47 PM
Catmaigne
Dec 25, 2014 12:16 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
