Stage 8 header bolts ?????
Old Feb 28, 2003 | 08:54 PM
Crazy8's Avatar
Question Stage 8 header bolts ?????
There is 2 choices on what do get: the 3/4" or the 1". What do most of you get. I will be installing the MAC headers
Old Feb 28, 2003 | 08:59 PM
RamAir95TA's Avatar
MACs have a relatively thinner flange than other headers, so you can get away with 3/4" bolts.
Old Feb 28, 2003 | 09:20 PM
Hyperspeed97z28's Avatar
does it mattter, you can use either or ? both will work?
Old Feb 28, 2003 | 09:21 PM
RamAir95TA's Avatar
Yes, you can use both.
Old Feb 28, 2003 | 09:24 PM
Sweet!
Old Feb 28, 2003 | 09:26 PM
Crazy8's Avatar
Thanks!!
Old Feb 28, 2003 | 10:35 PM
Bud M's Avatar
3/4" bolts may be easier depending on the header. With 1 inch bolts you may run into interference problems where you can't line the bolt up straight enough to get into the hole if the pipe is in the way.
Old Mar 1, 2003 | 09:17 AM
Scott 97 Z28's Avatar
Get the 1" bolts. They will grip into the head better and reduce the chance of stripping. One note with the stage 8's - the clips rattle under the hood. To solve this I used one coil off of a small spring behind each clip. It made it difficult to put the clips on but it's nice and quiet under the hood.
Old Mar 1, 2003 | 09:36 AM
they rattle but do they come loose?
Old Mar 1, 2003 | 10:33 AM
Bud M's Avatar
No, they don't come loose. Mine don't rattle either.
Old Mar 1, 2003 | 12:03 PM
DjArcadian's Avatar
I used the 1" ones as I had a bad experience with the 3/4" ARP bolts. If you have a dremel you could also cut them down too.
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
importkiller94
Jan 17, 2015 09:03 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
