Stage 2, 3.......carbon or ceramic?
Please suggest which clutch. Im thinking stage 3 but am not sure what material is better. What are the pros and cons. And how is the spec clutches with home install?
Mods: http://www.stevenetworks.com/z28/z28mods.php
I have the Stage 2, from your mod list I would say to get the Stage 3 Carbon. The Stage 3 Ceramic (trying to remember from the research I did last summer) is a "race only" and very harsh. It was recommended to me by a previous sponsor to get the Stage 2 for under 400hp and Stage 3 for above that. Your mod list look close to that magic number. But, beware you may need a 12 bolt soon if you don't have one already. That is what scared me away from the Stage 3.
I have driven a Stage 3 Carbon and when it releases, it really releases.
Chris
I have driven a Stage 3 Carbon and when it releases, it really releases.Chris
Stick with the Carbon, ceramic is some what harsher. Stage 3's will hold up to 680 ftlbs of torque. Also replace you input bearing
with a brass bushing to avoid what I am going through now. (BEARING DISINTIGRATION)
Locktite the flywheel bolts as well if you pull it off.
If anyone has any tips or recomendations on doing a clutch feel free to share
Spec redesigned their Spec 3 carbon to a 6 puck. The old 4 pucker design was having some quality issues. I can attest to that. Mine came apart on me and I am in the process of pulling it
out now and sending it back to SPEC. It lasted about 6 months
and not abused.
and not abused.
Henson071
Aug 4, 2015 09:32 AM
