SS Motor
The difference is in the SS-style airbox and the freer flowing exhaust, but the motors are identical. Keep in mind that the rating is just that - a rating - and doesn't prove a thing. Most Z28s and SSs will dyno (under identical conditions) about the same.
OK, I did not know that. Thanks
Replacement GM short blocks or having them converted by a reputable machine shop?
I can show you a 30th Anniv. SS with a 1,350HP engine, running low 8's....but that isn't relevant to the question, either.
But mine came with SS floormats so its faster.
Ram-Air Intake
SLP Stainless Exhaust with quad tips and a 3 inch cat back pipe
Eibach Suspension
Oil Cooler
1LE Thicker Swaybars
1LE Control Arms
1LE Panhard Rod
Torsen Differential and Aluminum Cover
ZR1 Rims- 275/40/17 tires all around
Hurst Short Throw Shifter
Ram Air hood
Revised Rear Wing
SS Floormats
SS Car Cover
Am I missing anything?
Ram-Air Intake
Eibach Suspension
Oil Cooler
1LE Control Arms
1LE Panhard Rod
Ram Air hood
Revised Rear Wing
SS Floormats
SS Car Cover
