SRP pistons
Old Jul 11, 2005 | 07:59 PM
ss#1230's Avatar
SRP pistons
anyone know the specs on SRP pistons PN 148988?
thanks jeremy
Old Jul 12, 2005 | 01:30 AM
atljar's Avatar
Re: SRP pistons
http://www.cnc-motorsports.com/produ...608&CtgID=8206
Old Jul 12, 2005 | 02:33 AM
ss#1230's Avatar
Re: SRP pistons
thanks for the info. so can they be used with stock rods or stroker rods?
also, it says they are made for super/turbo charged motors but the compression is higher than stock with stock heads with the -14 dish. doesnt sound right....
Old Jul 13, 2005 | 10:29 AM
arnie's Avatar
Re: SRP pistons
Originally Posted by ss#1230
... so can they be used with stock rods or stroker rods?
What did it state? The info is there.
... also, it says they are made for super/turbo charged motors but the compression is higher than stock with stock heads with the -14 dish. doesnt sound right....
What part of that don't you understand? Obviously, the application notes, are a 'blanket' approach, meaning it can be used for severe duty applications. It doesn't state you should use OEM size combustion chamber with these pistons, and run it in a FI application. Or is your question in regards to having a higher CR with a given size chamber, even though there is a negative dome (dish) in the piston crown? That answer being, CR is dependant on stroke, or stroke related. The longer the stroke, the more compression can be generated.
BTW, what is wrong with going to the source for info on SRP components? Where do you think the link provided got their info from?
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
