Squeeking noice from rear LCA's after Boxed BMR Install
Old 02-16-2003, 01:15 PM
G's Z28-LT1's Avatar
Squeeking noise from rear LCA's after Boxed BMR Install
Anyone have any ideas?
The only thing I can think of is that LCA's are held on with a bolt, nut and washer combo. Because the install procedures made no mention of putting the washer back on, I left it off.
What did you guys do (especially those w/no squeeks )? Did you go "!wahser" or w/washer?
Also, I'm running the stock LCA's.
Thanks.
G's Z28-LT1 is offline
Old 02-16-2003, 01:17 PM
RamAir95TA's Avatar
If they use poly/poly bushings, and you didn't grease them up, squeaking is normal.
RamAir95TA is offline
Old 02-16-2003, 01:24 PM
Sorry, I forgot to mention in my original post that I have the stock LCA's. I've since edited that post.
Old 02-16-2003, 03:51 PM
Janny's Avatar
Had this problem myself. Cured it by loosening the bolts at both ends, and re-tightening with full vehicle weight on the wheels. A bit awkward to get at but . . .
Janny is offline
Old 02-16-2003, 04:25 PM
I'll give it a try... Did you use washers on the LCA's or just the Bolt/Nut combo provided by BRM?
Old 02-16-2003, 04:44 PM
Z95m6's Avatar
I think you just need to tighten up the LCA bolts alittle more.
Z95m6 is offline
Old 02-16-2003, 04:53 PM
Fear The Z's Avatar
I love it when I know someone with an alignment lift
Fear The Z is offline
Old 02-16-2003, 05:06 PM
97 WS6 T/A Conv's Avatar
Mine did the same thing. Drop the LCA at the end where it connects to the body of the car. Grease the bushings on both sides where they touch car metal, no more squeak. No washer used.
You could grease it at the other end as well if you still hear a squeak but mine was at the car end and not at the axle.
97 WS6 T/A Conv is offline
Old 02-17-2003, 12:23 AM
Thumbs up
Great, I took your advice and no more squeek. With any luck, it won't come back in a week
Thanks for the help guys.
Now, if I can only figure out my ongoing alignment problem...
10-31-2016 11:09 AM
Richardan15
05-30-2015 08:36 AM
lbrowne
11-13-2011 04:25 PM
DubbyZ28Camaro
08-04-2002 12:53 PM
Quick Reply: Squeeking noice from rear LCA's after Boxed BMR Install
