Squeek in Pulleys
Old Aug 5, 2007 | 06:49 PM
CamaroSS8887's Avatar
Squeek in Pulleys
My car has started squeeking/ rattle. Sounds like the pulleys.. How would i fix that.. Just pulleys are bearings and everything. and im uessing that is what the problem is.
Old Aug 5, 2007 | 07:17 PM
96capricemgr's Avatar
Most likely culprit is the tensioner, cheap and easy to fix.
Old Aug 5, 2007 | 08:10 PM
n2ceptor's Avatar
Pulleys cost around 20~30 dollars.... If you have a bearing remover/installer press, bearings cost around 5~12 dollars....
As mentioned by 96capricemgr, might be the tensioner, cost around 35~40 dollars.....
Use metric wrenches/sockets... Dont remember size..... Easy to replace....
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
99_Z_155
Jul 25, 2002 08:46 PM
