squealing from top of motor i think
Old Apr 9, 2008 | 08:59 AM
el tea one's Avatar
i have a 97 z28 pretty much stock with a squeal that gets louder when it heats up.i can't hear it when i accelerate but that doesn't say much and it still runs strong
Old Apr 9, 2008 | 09:23 AM
Austin_78@msn.com's Avatar
check your belt.
have you spilt antifreeze or anything on you engine??
Old Apr 9, 2008 | 07:16 PM
el tea one's Avatar
as a matter of fact a coolant hose got a hole in it so i will have too say yes
Old Apr 9, 2008 | 07:22 PM
el tea one's Avatar
oh and i'm not sure about alot with this car i just got it yesterday for 2000 bucks because of the squeal the owner thought it was piston slap
Old Apr 9, 2008 | 08:18 PM
el tea one's Avatar
any one
Old Apr 9, 2008 | 08:59 PM
el tea one's Avatar
okay so it is not audible until it warms up and goes with the rpms any help would be great please please please
Old Apr 9, 2008 | 09:06 PM
el tea one's Avatar
please
Old Apr 9, 2008 | 09:23 PM
Stl94LT1's Avatar
Pull the serpentine belt and see if it goes away. This could be the alternator or A/C compressor. Also check the weep hole on the water pump, it's bearings could be shot.
Old Apr 9, 2008 | 09:32 PM
el tea one's Avatar
okay sorry bout this but where is the weep hole and what am i lookin 4
Old Apr 9, 2008 | 09:35 PM
Stl94LT1's Avatar
It's on the lower side of the water pump. If it is oozing coolant, the pump is shot.
Old Apr 9, 2008 | 09:47 PM
el tea one's Avatar
i will check that as soon as i get light outside and thanks for taking the time to help me out they should just make a sticky on squeeky lt1's thanks again
Old Apr 10, 2008 | 09:46 AM
87bandit's Avatar
if you have a hose leaking coolant then it's probably getting the belt wet = squeeling belt
Old Apr 10, 2008 | 02:43 PM
el tea one's Avatar
alright so it's not the belt and no leaking weep hole i got underneath the car and it sounds like it is coming from where the motor hits the tranny .i made sure the bolts were tight but i still get the noise
capebuf
Jan 13, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
