Squeaking sound............?
I have a squeaking sound coming from the driver side rear what could it be. Someone told me it could be the shock or an exhaust hanger broke. Does anyone else have this problem? My car (which is a 1997 trans am) and my friends car (which is a 1999 camaro z28) both do it.
Please help, thanks
-James
Please help, thanks
-James
Originally posted by frmula1
you sure its not just the brakes?
does it happen like when you go over bumps and ****?
The same thing happens to me.. Unfortunantly I can't find what it is, I've had friends crawling around the back that just couldn't find out what the hell it is, drives me friggin crazy, try the LS1 Tech section and the post might stick around a little longer.
Originally posted by SunCoastTA
Naw i can be sitting at a red light and it starts doing it. My car does vibrate alot because of the exhaust, but it is an annoying squeaking sound.
I have crawled under and tightened anything that looked like it could be tightened and greased anything that culd be greased, and still have it, if you find out what it is let me know.
Originally posted by Fatdog
Might try folding the rear seat down.If the sound goes away,then wrap electrical tape around the rear seat connector posts.Hope this helps.
I tried that, actually my rear seat has been down for a couple of days now and it was doing it really bad today.
Maybe its like the F-body birth mark - no one knows where it comes from
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
The American dream
werd!
jack the car up... and turn it on... when it starts making the sound... i would just hop underneith and stick my ear in the direction it was coming from...
other than that...
uhh... does it sound like its coming from something that rotating? ie: drivetrain?
