squeaking from front driver's side
Old Mar 7, 2004 | 02:15 AM
Detroit808's Avatar
Something's squeaking when I go over large bumps/potholes at moderate speeds. It was there from a short while ago, but has been getting worse the past few days. The sound is a short, high-pitched squeak/chirp, almost like that of a metal birdcall. Any ideas? I'm pretty sure it's coming from outside the car around the front driver's wheel, but it's difficult to pinpoint, considering the car needs to be moving to hear it.
Old Mar 7, 2004 | 11:58 AM
Detroit808's Avatar
up
Old Mar 7, 2004 | 12:26 PM
Kryckter's Avatar
Ill give some suggestions. I would guess it is a bad strut or bad control arm bushings. One way to check is to jack up that side of the car and kick on the tire. If it shakes and moves its possible you have a bad a-arm bushing. That may squek. Another suggestion is the bad strut, It may squek or make a noise on bumps. Check those out and maybe some other bushings like sway bar or anything on the front. Good luck!
Old Mar 7, 2004 | 09:16 PM
Fatdog's Avatar
Cool
It's a common thing I think.I just hit the A arms bushing this morning with wd-40,and the squeek went away(for a couple of months anyway).Also if you pop the hood,hit the shock bolt rubber thing with a coulpe of hits of wd-40,that might help.(cover with a rag so it doesn't splatter all over the place though.)Hope this helps.
dale3in98
Feb 14, 2015 12:18 PM
Hurin
Dec 13, 2014 07:38 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
JSK333
Sep 9, 2002 10:33 PM
