squeak?.....help!!
Old Oct 19, 2004 | 10:51 PM
arklie's Avatar
squeak?.....help!!
Hi,
During cold starts, my car has this squeaking noise coming from the engine. It's not constant, but quick and repetative. Once the car is warm, it goes away. My mechanic is not sure what it is just by listening to it. Anyone know what this might be? I've been told it might be a water pump bearing, but why would it go away once it warms up? Any info would be great. Thanks
Old Oct 20, 2004 | 10:23 AM
ShawnMacAnanny's Avatar
Re: squeak?.....help!!
Check your serpentine belt. Mine is cracked and squeaks when it's cold. It goes away eventually though. The previous owner could have used some belt dressing on it too. Also if you have spilled antifreeze on it, the belt will squeak. Mine did for a few days hten went away. It's only there at start up but thats because i have a 12" long crack in my belt .
Old Oct 20, 2004 | 12:05 PM
southern78's Avatar
I changed me tenisoner and ztill had the squeak. Well change my serp. belt and it was gone. Got the gator belt and it hasn;t squeaked sense.
Old Oct 20, 2004 | 02:35 PM
americanmusscle's Avatar
A test to see if it is the belt is ( I did this on my 84 monte many times last resort option) take a can of WD-40 and spray it on a cloth or if you trust yourself lightly spray the belt. If it goes away then there is your problem. This is just a suggestion and it is intended to just give you another option. Its up to you to try it.
Ferocity02
Dec 1, 2003 12:02 AM
Ferocity02
Aug 6, 2003 01:55 PM
camaro98_speed
Jul 31, 2003 03:44 PM
TheV6Bird
V6 Tech
9
Jul 13, 2003 11:54 AM
scoobysnax83
Feb 18, 2003 01:54 PM
