sputtering after key is off
Old Jul 24, 2008 | 11:53 PM
Maverick_997's Avatar
1997 z28 6 speed (not the one in sig)
when i turn the key off it will run on doing that sputtering thing fro about 1-3 seconds depending how long it was run for.
timing is my guess but i though all that was done electrically
also has lag during acceleration but when held at a constant rpm it runs fine
need help
Old Jul 25, 2008 | 05:35 AM
Guest47904's Avatar
Guest
Engine needs cleaning
Timing has nothing to do with when the key is off. Sounds like you have a couple of issues. Probably a large build up of carbon and the throttle plate is probably adjusted open too far to compensate for a poor idle.
This is the only stuff to put in the engine.
Only available at dealers.
Old Jul 25, 2008 | 08:02 AM
Chevyguy358's Avatar
I know on one of my other vechiles i had run on I believed caused by high compression and hot cylinder temps...but that is prolly a bit different
Old Jul 25, 2008 | 12:33 PM
WS6T3RROR's Avatar
Although I agree with speedy. I feel that it is probably a leaky injector. Reason being is nothing will happen without sufficient fuel and air. You can get plenty of air through the tb at stock setting to fire a single cylinder a couple of times. But it can also be from poorly adjusted throttle blades. Carbon and too hot of a spark plug will do it also.
68camaroboltz
Oct 5, 2015 11:56 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
