sputter,backfire, then runs fine...
Old Mar 24, 2007 | 11:58 PM
reamo04's Avatar
alright guys, so i was out driving around tonight, when all the sudden i would get a sputter at about 1700, and then about 2k it would backfire, and then after 2200 or so it would run perfectly fine and pull like a raped ape.It will run really rich during and right after this though
Background of the car:
just got longtubes and true duals march 10th
just did an OTVC plug wire setup yesterday
newer spark plugs (5k on them MAX)
otherwise perfectly stock
isnt throwing codes or anything
Old Mar 25, 2007 | 01:14 PM
reamo04's Avatar
anyone?
Old Mar 25, 2007 | 02:32 PM
zlighting's Avatar
If you just did a an OTVC plug wire setup yesterday, and the backfiring started afterwards; check the firing order, you may have crossed a wire.
Old Mar 25, 2007 | 02:47 PM
LiENUS's Avatar
Check your MAF sensor too I had similar symptoms. SD Tune later and my problems went away
Old Mar 25, 2007 | 03:04 PM
Feenix's Avatar
See if ya burnt a hole in one of the wires,, I know you said OVTC but I Had a buddy that installed OVTC yet, somehow had one of his wires slightly meet up with a primary and burnt a tiny hole in the side and started misfiring and hesitating at low rpm.
Old Mar 25, 2007 | 04:10 PM
reamo04's Avatar
yeah, i had that problem, with 2 wires (zip tie broke and my 2 wires were touching), got it fixed, and now it does it at about 2200, but not near as bad. Im thinking i may have a fouled plug somewhere. I know i need a tune since my car is running really rich after the headers/exhaust.
Old Mar 25, 2007 | 09:42 PM
reamo04's Avatar
up for the evening, it still does it if i get on it more than like 1/4 throttle, like its feeding in too much fuel?
Alex Barnes
Jan 24, 2015 10:21 PM
1775.Z28
Jan 11, 2015 10:51 AM
F(ast)-body
Feb 26, 2003 09:05 AM
supercharged94Z28
Feb 24, 2003 10:22 PM
Ryabut98
Sep 3, 2002 11:45 PM
