Spun rod bearing??
Old Apr 21, 2005 | 09:49 PM
94TEALz's Avatar
Spun rod bearing??
Ok I have a noticable "knock" coming from the engine bay somewhere,really havent gotten to deep in it. I have really good oil pressure and runs fine but the sound its in sink with the rpm. I would of thought of a lifter but i woudl think a collapsed lifter would maek it stumble and miss? any help would be great.
Old Apr 21, 2005 | 09:53 PM
markinkc69z's Avatar
Re: Spun rod bearing??
Make sure your accessories are tight on the brackets.
Old Apr 21, 2005 | 10:47 PM
IrocSS85's Avatar
and make sure the torque conv. bolts are not loose. you should jaclk up the car and listen to the eng. from underneath. if its a rod knock it'll be louder underneath. good luck. mine turned into a 383 project.
chris
Old Apr 22, 2005 | 11:13 AM
1-bad-z28's Avatar
chris
mine turned into a blown 355
Old Apr 22, 2005 | 12:25 PM
raroz28's Avatar
check your engine codes. Might have a misfire. A bad spark plug/wire or loose plug/wire will cause a misfire and sound like a knock.
2QUIK6
Sep 17, 2016 02:31 PM
Devinfoote87
Feb 12, 2016 03:21 PM
KYWes
Aug 10, 2015 07:03 PM
NewsBot
Aug 3, 2015 10:26 PM
mrwz28
Jul 8, 2015 09:11 PM
