spun bearing?
Running the car low on oil (the engine looses oil pressure and spins the bearing as shoebox said). A failed bearing is normally caused by a damaged journal or even a defective bearing in rebuilt engines.
I've heard excessive RPM will spin a bearing but not sure why
wrong sized/clearanced bearings will do it too.
there's supposed to be .002" between the bearing and the journal. if there's less, it will be tight and the oil will not flow freely. if there's too much, the oil will move out of the way and the journal will actually hit the bearing, and not glide on oil. when the journal hits the bearing it moves...and then it's spun...and then you have to replace or fix the crank and use specific bearings for your journal.
If the motor has a ton of mile on it, the rod "big-ends" will begin to get egg shaped. The cap especially will become deformed. It's mostly normal wear and tear. So evenually the rod will not be able to hold the bearing shell.
Upon engine start up the loose bearing may stick to the crank journal and it's down hill from there.
(that's another way to spin a bearing).
Karl Ellwein
Karl Ellwein
but the engine was never rebuilt. and 105k but ran like a dream for the seven our trip before i spun the bearing. i just hit a water puddle and it died. no oil in motor tho. don't know how i did it?
well, mainly because of this:
Originally Posted by FlamingChicken
Cant you also spin them from debris (dirty install, other failures, etc)? the debris gets in the bearing and chews everything up then spins.
jackpawt883
Sep 10, 2015 08:53 PM
I attributed it to worn bearings and insufficient oil pressure at high RPMs.
