Spun bearing
Old Aug 20, 2003 | 03:32 PM
BigBlue95Z's Avatar
Spun bearing
What exactly happens, what caues it, and how can you tell that you did it. I hear about it all the time on a camed car and was wondering what can be done to prevent it/fix it. I am planning to put a cam in my car and it will have approx 100K on the motor. Thanks!!
Old Aug 20, 2003 | 04:18 PM
Fastbird93's Avatar
Basically, the two piece bearings on the rods or crank get worn down due to poor oil circulation, high operating temps, contaminated oil (junk in it), ect ect. One side "spins" under the other, causing a gap, which is where you get the knocking from. they chew themselves up, spreading bits of metal all over the inside of the motor. Not cool.
Preventative?? Regular oil changes, keeping the operating temps down, hence keeping the cooling system in good working order.
As for a cam causing it, with a cam you're putting a greater strain on the engine than before. It's completely possible that the motor was weak to begin with.
Old Aug 21, 2003 | 01:42 AM
BigBlue95Z's Avatar
So if it happens, your block is pretty much toast?? Or is there a way(cheaper) to fix it??
Old Aug 21, 2003 | 02:28 AM
atljar's Avatar
The block should be salvagable, but best case is you hone the cyl walls, turn the crank, and replace all bearings. This is the time most people go 355 or 383
Old Aug 21, 2003 | 08:34 AM
thewinner's Avatar
Not necessarily. Spun bearing means the to bearing halves spin around so the gap between them is no longer where the caps/block or cap/rod meet.
This movement misaligns the bearing holes with the holes in the block, causing your low oil pressure.
Lack of oil is the number one cause of bearing failure IMO. Not **** in the oil, cause the filter will catch most of it and the rest will pass right through.
On the block being salvagable, in most cases yes, in some no. Stop running it if you think somethin is wrong.
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
95craz28
11
Sep 12, 2015 07:47 AM
jackpawt883
Sep 10, 2015 08:53 PM
