springs to use with cc306 cam
Old Aug 27, 2004 | 04:53 PM
Matt1997Ta's Avatar
anyone know what springs i should use so i dont have to machine my heads also am i correct in assuming that i needs stock length hardened pushrods?
Old Aug 27, 2004 | 05:10 PM
xxsaint69x's Avatar
Re: springs to use with cc306 cam
crane 10308 kit..comes with everything you will need Shims, locks etc.
Marcin
Old Aug 27, 2004 | 05:30 PM
simple's Avatar
CC985-16's will work great also
if you look thru a parts catalog (Jegs/Summit), most pushrod manufacturers recommend a slightly longer pushrod with aftermarket Comp cams, usually a 7.25" with HR valvetrain over the stock 7.2"
best way to do it is check length after isntall with an adjustable pushrod legnth checker (~$20), then order new ones if needed
Old Aug 27, 2004 | 06:44 PM
S8ER95Z's Avatar
99893-16
These are what the guy who sold me my engine is setting me up with. I dont know about pushrods, but I plan on using the stockers with the stock 1.5rockers.
EDIT* - must machine spring pockets? wtf.. i need to talk to him again.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
grabbem88
Feb 22, 2015 11:16 AM
StansZ28
Feb 19, 2015 07:39 AM
