springs for the iron heads?
Old May 31, 2004 | 03:09 AM
ThirdGenLT1's Avatar
95 Iron Lt1 heads, need springs to support the 224/230 (believe it's the cc305). Do the iron heads have the same diameter as the aluminums? I was over on the impala board and their suggestions are all over the place for the iron heads. Can I get some springs/retainers for these heads that won't require machining?
Thanks, matt
Old May 31, 2004 | 03:28 AM
Spinner's Avatar
Looks like I stand corrected. LEarn something new every day
Old May 31, 2004 | 08:19 AM
bunker's Avatar
The seats are smaller on the iron heads, you can't get as big of springs for them without machining & I don't think the ones mentioned woulf fit either. Not only that, the iron heads have holes where the pushrods travel instead of one big hole, so with increased lift the pushrod might touch the head & rub or break things.
Old May 31, 2004 | 08:44 AM
96capricemgr's Avatar
Iron heads use a smaller pocket.
Here is the thread you need, http://www.impalassforum.com/cgi-bin...c&f=1&t=004804 I would say you need the 613s.
Old May 31, 2004 | 02:34 PM
Hey, Thanks for the help
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
Don 97 SS
Jul 11, 2005 08:50 AM
