Spring recommendations for 503 cam
Old Aug 5, 2006 | 03:47 PM
camaroman4ever's Avatar
Just like the title says, what are you guys running or would recommend with the CC 503? Didn't pull much info up with a search.
Old Aug 5, 2006 | 03:53 PM
Javier97Z28's Avatar
Moderator
Re: Spring recommendations for 503 cam
beehive 918's are fine
Old Aug 5, 2006 | 04:44 PM
moserman's Avatar
any double valve spring will do, check out crane 10-308 springs, they are popular
Old Aug 5, 2006 | 05:46 PM
PoorMan's Avatar
Comp Cam 987 is what I am using. Good for .600 on paper but .580 to be safe. Install height was 1.800 I believe.
Old Aug 5, 2006 | 11:28 PM
Thanks for the replies so far guys.
I forgot to mention I'll be using stock valves, if it matters. And I'd like to use something that doesn't require any machine work.
I was already leaning towards the 918's a little bit. At the same time, the insurance of a double spring would be nice too.
Old Aug 5, 2006 | 11:39 PM
hvyss's Avatar
I use the CC 26918 behives with my CC503 and LE2 heads.
HVY SS
Old Aug 6, 2006 | 10:01 AM
Dave '97 Z28 M6's Avatar
I'm running the 918 beehives here... they're a good spring for the CC503 due to the ability of the beehives to control valve action with the CC503's steep lobes.
Old Aug 6, 2006 | 11:29 AM
zx1216's Avatar
i'm runing the 918's on my cc306 with no problems so you should be fine.
Old Aug 7, 2006 | 11:06 AM
Anyone else have anything to add?
I appreciate it everyone
Old Aug 8, 2006 | 06:53 PM
Alright, I picked up the 918's
I have a couple other questions.
First, what valve spring compressor are you guys with 918's using? I don't have one at all so I need to get one but I don't want to get something that won't work with the smaller diameter on the top of the spring/retainer. I know a lot of the ls1 guys use a pedastal type but i havn't seen any of those for much less than a hundred bucks, and this tool factors into my overall budget so something a little cheaper would be nice.
Next, since the heads are off and being cleaned up, I was going to replace the valve seals. What size and type of seal do I need?
carl.froehlich
Mar 13, 2015 12:38 AM
grabbem88
Feb 22, 2015 11:16 AM
Queens94z28
Nov 20, 2014 06:03 PM
Don 97 SS
Jul 11, 2005 08:50 AM
