Spring recommendations for 503 cam
Re: Spring recommendations for 503 cam
Thanks for the replies so far guys.
I forgot to mention I'll be using stock valves, if it matters.
And I'd like to use something that doesn't require any machine work.
I was already leaning towards the 918's a little bit. At the same time, the insurance of a double spring would be nice too.
And I'd like to use something that doesn't require any machine work. I was already leaning towards the 918's a little bit. At the same time, the insurance of a double spring would be nice too.
I'm running the 918 beehives here... they're a good spring for the CC503 due to the ability of the beehives to control valve action with the CC503's steep lobes.
Alright, I picked up the 918's
I have a couple other questions.
First, what valve spring compressor are you guys with 918's using? I don't have one at all so I need to get one but I don't want to get something that won't work with the smaller diameter on the top of the spring/retainer. I know a lot of the ls1 guys use a pedastal type but i havn't seen any of those for much less than a hundred bucks, and this tool factors into my overall budget so something a little cheaper would be nice.
Next, since the heads are off and being cleaned up, I was going to replace the valve seals. What size and type of seal do I need?
