spring pressure question
Old Jun 2, 2005 | 08:53 PM
KyChad350's Avatar
i just bought a set of ported heads and the springs were tested at 150 lbs. does this mean i need new springs or could use those for a while
Old Jun 2, 2005 | 09:43 PM
1racerdude's Avatar
Re: spring pressure question
What cam??
That is enough to cover all but the most radical hyd roller.
Are the springs new or used? If they are new they will loose some 15-25# after break in and still be OK.
Old Jun 3, 2005 | 07:28 AM
KyChad350's Avatar
they are used and im running the 306
Old Jun 3, 2005 | 07:39 AM
30696bird's Avatar
I had the same question the otherday. I called compcams and they said I only needed 120# of seat pressure and 310# of open pressure............you'll be fine. I wish I had them!! LOL I'll be buying some from sstrokerace here in the near future.
Old Jun 3, 2005 | 12:06 PM
1racerdude's Avatar
You are good to go..
Noenav
Mar 1, 2019 07:38 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
Louey
Pacific
Nov 28, 2014 03:46 AM
Jul 4, 2005 05:00 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
