which spring compressor to use
Old Feb 18, 2008 | 04:19 PM
  #16
89385formula's Avatar
Originally Posted by Sinister95Z
While in the middle of my cam/spring swap, the best thing I did was invest some money into "Tim's Tool" over on LS1tech.com. Do a search for it and it will pop right up. It allows you to change the springs without removing the heads and has an optional pre-assembled air compressor fitting to fill the cylinder with air to prevent dropping a valve.
He shipped the tool out to me very quickly and everything was quality made. It is only $30 for the tool, and then $50 if you want the compressor fitting.
A buddy of mine that is helping with the build fell in love the first time he used it. I gave the tool to him just for helping me out so much
x2. Tim's valvespring tool or the crane tool both work very well.
Old Feb 19, 2008 | 06:16 PM
  #17
Ken95Z28's Avatar
The Tim tools does not work very well with tall springs, bought it and it does not work with my setup. Just wanted you to make sure that you are informed about this.
Old Feb 22, 2008 | 03:27 PM
  #18
sn8ke eatr's Avatar
whats "your setup". by that do you mean dont work well with your springs? what springs are you running?
Old Feb 22, 2008 | 03:37 PM
  #19
Ken95Z28's Avatar
Those are 914's installed height 1.800
Old Feb 22, 2008 | 03:47 PM
  #20
Javier97Z28's Avatar
Moderator
I've used that thing a couple of times... not a big fan of it.
Better than some others I guess.
That being said, I'll never use anything but the crane tool ever again.
Old Feb 22, 2008 | 03:52 PM
  #21
MEAN LT1's Avatar
Agreed, Im using the crane tool right now and I love it. Even on the taller springs all I do is push it down a tad to engage the nut and im in there.
Old Feb 22, 2008 | 04:30 PM
  #22
The Engineer's Avatar
It don't get any better that the Crane tool for a heads-on valve spring R&R! Probably about the best thing to come out of Florida ever!
WD
plz28
May 14, 2015 09:28 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
