Sprayed the LE2 setup >>>>
Old Mar 27, 2005 | 10:35 PM
  #16
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
Re: Sprayed the LE2 setup >>>>
My traps could be hurting some from the fact that I'm not at sea level, nor was the DA close to even 1000' on friday.. Who knows. It weighed 3465 w/ me out of it, I know the roll bar and 12 bolt weigh it down.
The car has it in it to run, after all - in some nice neg. DA air, I've trapped 106mph w/ just a cutout and cold air... And 114mph w/ full bolt ons and 224/236 XE cam on stock heads. But that was 5 years ago . Drag radials on 16 inch wheels, yadda yadda. My car in it's form now will no way set any kind of records, but I'm okay w/ that.
Old Mar 27, 2005 | 10:48 PM
  #17
trans9_5am's Avatar
Originally Posted by Shawn 97 Z28 M6
forged slugs and stock everything else, as far as the short block goes. top end of the motor includes comp pro magnum rockers w/ comp r lifters and an AFR rev kit, AS&M 58mm tb, and SLP CAI.
drivetrain is a spec stage 4 clutch, 3.5inch PST alum. driveshaft, and KTRE 12 bolt w/ 4.11's.
exhaust is pacesetter LT's w/ 3inch custom y pipe and a 3.5 inch intermediate pipe into an SLP 2odl muffler.
Is a AFR Rev Kit really necessary with the LE2 setup?
Brandon
Old Mar 28, 2005 | 12:09 AM
  #18
SStrokerAce's Avatar
No, you can just do a beehive spring setup and if you want some additional help, get the Ti retainers and you should be golden.
Bret
Old Mar 28, 2005 | 12:12 AM
  #19
96ta(nick)'s Avatar
I am only trapping 114 with heads, cc306 dynoing 390
I still have not figured out what is up with my piece.
Jeff1904
Jun 5, 2016 05:00 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
damnyankee36
Sep 9, 2015 07:06 PM
