Spray or No spray
Old May 4, 2004 | 11:22 PM
1984camaroz28's Avatar
Spray or No spray
Still thinking about spraying my 383.... I have a kit now Cast crank and hyp pistons. This means i whould have to buy new pistons crank and rods. My car has 4.10s now my goal is to be in the low 12s high 11s
383
11 to 1 comp
cc306 cam
1.6 RR
Trick Flow heads
Ported LT1 intake.
with a good hook what do u think my car whould run in the Ball park. I forgot to say im curently spraying my car now with a 100 shot.
Old May 5, 2004 | 01:22 AM
25thBird's Avatar
i say you should be in the 12's with out the shot and possible in the 11's with it... i could be wrong, but sounds like you could there already...
Old May 5, 2004 | 01:38 AM
96ta(nick)'s Avatar
i am knocking on 11s with my setup without spray and on a stock bottom end. I just need to get some tires and my worn out suspension taken care of and i should be there. If all you want is 11s you should get there on motor pretty easy..
As soon as i get a 12bolt i will be looking for 10s on spray
Old May 5, 2004 | 08:34 AM
80TA's Avatar
Engine should stand up to 100 to 150 max shots without having to have forged cranks and pistons.100 shot is very safe and will chop a full second usually assuming traction.
Spray it..!!
Old May 5, 2004 | 11:41 AM
Im woried tho the crank is only rated to 500hp its cast.
Piston I plan on using
Rods are not an issue I got a good set.
Will they hold a 100 shot or even a 150 shot
Old May 5, 2004 | 09:05 PM
anyone....
Old May 6, 2004 | 12:00 PM
i think im just gona go all forged to be safe
Old May 6, 2004 | 12:30 PM
T/A lt1's Avatar
Forged is the way to go but N/A it will be OK but on n2o those pistons are not the greatest. With decent heads your car should run 11's easily N/A. Look at my sig.
Old May 6, 2004 | 01:43 PM
rskrause's Avatar
Moderator
That's a very inappropriate piston for nitrous use. I believe it's a light weight piston for "restricted" applications. Why did you chose that piston?
You might want to look at my thread in "N2O Tech" for some tips on nitrous engine building.
Rich Krause
Old May 6, 2004 | 08:46 PM
i got it for nothing from a friend. im still considering what to do.... i just cant make up my mind
Old May 6, 2004 | 08:53 PM
will this rod hold up to a 150 shot of spray
Old May 6, 2004 | 09:06 PM
gb95zconv's Avatar
Best route for you IMO too. I would want some forged slugs for spray....the rest of your setup would be ok
Old May 6, 2004 | 09:20 PM
but my Na setup whould be pushing the limits of the crank as it is. u spray 150 to that thing at it mite get a lil hary
Jeff1904
Jun 5, 2016 05:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
30th Anniv Z28
Aug 1, 2015 10:39 AM
RX Speed Works
Jul 24, 2015 02:25 PM
