Spohn LCA relocation brackets...
I bought these a while back because I lowered my car, but I have since raised it back up and am running into some traction issues. I have noticed that they are two way adjustable. Which setting would be best for the V6 spring trick?? I believe they are on the lowest setting they can go right now.
Any help is appreciated...
Well mine seemed to make the most difference on the lowest, another guy I know that has them said the same thing. I think you really need the new control arms to really make them work well, since they flex it'll give you some wheelhop and not let you hook well.
Already have the lower control arms...he he...the only thing that isn't aftermarket in the rear suspension is the torque arm.
So the lowest setting it is then. Looks like that makes less work for me.
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
