Splicing Wiring harness to extend O2's
Old Jul 30, 2004 | 12:26 PM
aram's Avatar
I'm switching over to a 94-95 computer/harness over my 93 computer right now. I have a set of jet hot long tubes and am going to need to extend the harness.
I've heard a lot about slowing the response of the O2 sensors if you splice an extension in rather than using a pre-made connector.. does anyone know if there is a problem in extending the actual harness (soldering) or should I just use a set of extensions. It'll save me the hassle and money if I can just extend the harness, but if the O2's will never work correctly after doing it I'll just order the damn extensions.
Old Jul 30, 2004 | 12:36 PM
944v8inDFW's Avatar
Re: Splicing Wiring harness to extend O2's
slowing response of the O2 sensors if you splice an extension in rather than using a pre-made connector an electrical urban myth!
Actually if you extend with quality wire and solder all joints on your o2's you will have less resistance that another set of connectors from extentions.
Old Jul 30, 2004 | 12:57 PM
Extend the car's harness and not the harness made onto the O2s, themselves. The O2s get reference air through their wiring, so it is best not to disturb it.
Old Jul 30, 2004 | 01:07 PM
sweetassz's Avatar
Ive had mine crimpt for a few years. No issues here.
Old Jul 30, 2004 | 01:49 PM
aram's Avatar
Thanks. I'll do everything at work and used some quality solder. Anyone know how much to extend the harness?
Old Jul 30, 2004 | 07:53 PM
Brent94Z's Avatar
Super Moderator
For my Hooker Long tubes, I extended mine 6" and 13".
Old Jul 30, 2004 | 07:55 PM
turbo_Z's Avatar
I bought some extentions from LS1speed.com.. they are the cheapest I could locate and really save time for when the O2s die and need replacing.
siguy
Nov 27, 2014 10:07 AM
gh0st
Sep 1, 2002 10:24 AM
Teal94V-6
Aug 31, 2002 09:21 PM
CobraEatr
Jul 23, 2002 06:32 PM
