Speedo With Th350???
Old Nov 10, 2003 | 12:10 PM
MRBORAT's Avatar
What is available to make the speedo work on a 350 turbo conversion. Thanks-
Old Nov 10, 2003 | 12:52 PM
Shon Herron's Avatar
Depends on what PCM your vehicle came with...this determines what options are available...ie free or $$.
Old Nov 10, 2003 | 04:23 PM
MRBORAT's Avatar
It's a '95 so its an OBD1 pcm. I've got tuning software but dont know what else I need.
Old Nov 10, 2003 | 05:11 PM
conquest lt1's Avatar
jags that run sell a conversion kit, i think.
you need to install a gm vehicle speed sensor in place og the worm gear stuff that is on it now.
go here:
jags that run speedo page
this plugs into the worm gear stuff and passes a signal of to the pcm.
Old Nov 10, 2003 | 06:59 PM
TAChad's Avatar
if you have the short tailshaft i can help ya out. if you have the 9" im not sure yet. is the tranny outof the car? i can get you a kit that uses the 4l60e tailshaft housing, and you use the shaft that comes with it with the 4l60e sensor and it works great.
Chad
Old Nov 11, 2003 | 07:19 AM
MRBORAT's Avatar
Yeah, I've got the 9" tailshaft. The transmissions already in the car so I'll probably just try the conversion setup, dont drive it much so its really no big deal but it would be nice to have it. Thanks for the info.
Sep 27, 2015 01:55 PM
mmf_1013
Sep 12, 2015 08:56 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
LazyLemming
Aug 29, 2015 07:36 PM
4586
Aug 24, 2015 11:04 PM
