speed pro pistons
speed pro pistons
would the speed pro forged pistons part #trw-l2304f30 be to high of a compression on a street strip car with basically factory casting heads :had a port job done on them: or interfere with valve clearance issues with a cc306 cam on 1.6 rockersor would they be ok
I think the CR wuill be higher than you want, though to be sure we would need the rest of your specs, as already pointed out. ASSuming (dangerous) typical 30 over 350 dimensions and a 0.039" gasket would put you around 11.8:1
Rich
Rich
stockssn2o
May 25, 2015 08:54 AM
