Speed Pro Forged Pistons..
Old Nov 26, 2006 | 06:37 PM
hotrod18_69's Avatar
I've got my engine out and checking it over.. She's got over 115K on her.. And was thinking about dropping a new set of pistons in along with all the bearings and such..
I found these on Summit.. Anyone running them? And will they work. I know the stock pistons have a short skirt and i'm pretty sure these have a long skirt.. Not sure if thats gonna cause any issuse's..
http://store.summitracing.com/partde...5&autoview=sku
All i'm doing is freshing up the bottom end for CC 306 and set of heads pretty close to the LE2's.
Let me know what you guys think.. I'm pretty sure they'll work. Just wanna make sure..
Brad
Old Nov 26, 2006 | 06:51 PM
automotivebreath's Avatar
The only problem I know of with the 2256 pistons are the weight, they are on the heavy side. Search for TRW-LW-2256F30, they are lighter.
Old Nov 26, 2006 | 06:52 PM
Ok, thanks. I'll look them up..
Old Nov 26, 2006 | 06:57 PM
quickSS's Avatar
Obviously these are .030 over pistons. Are you boring to 4.030" ?
Kinda looks like you are just doing a refresh of the stock motor and not a bore and hone.
Karl
Old Nov 26, 2006 | 07:02 PM
Yeah i just noticed that.. I may go over to .030 I need the get the block to the machine shop.. The walls look pretty good right now. Just alittle wear on the sides.. I am gonna have it honed if it doesn't need a bore.. Does speed pro makes these in STD bore.. I'm sure they do, just can't seem to find them..
Old Nov 26, 2006 | 07:33 PM
quickSS's Avatar
I'm sure Speed Pro does make a 4.000
But maybe consider going to a super premium Mahle piston for only around $500 bucks, (with probably the best rings for the money). $270 for these Speed Pros vs $500 for the Mahles. That's not a lot of beer money.
Karl
Old Nov 26, 2006 | 08:02 PM
WS6T3RROR's Avatar
I have had decent luck with the 2 valve relief cheapy speed pro pistons.
Old Nov 26, 2006 | 08:25 PM
Karl
The more i look into the speed-pro. quickSS your right.. I think i'll just go with the Mahle set. I've heard nothing but good things about them. And might as well, its cheap insurance if i ever want to spray a 150 shot..
Old Nov 26, 2006 | 08:27 PM
Where's the cheapest place to get the mahle's?
Old Nov 26, 2006 | 08:40 PM
quickSS's Avatar
Flatlander Racing,
LINK direct to the Mahle spot at Flatlander
hth,
Karl
Old Nov 26, 2006 | 08:44 PM
RedLT4Mike's Avatar
Theres a guy over on fbody.com that ran the heavy speed pro
pistons with a 250 shot for a long time and ran 9s.
Im not sayin that they are optimal, but they handle good power.
Old Nov 27, 2006 | 12:39 PM
Just out of curiosity, how much do the 2256's weigh?
Old Nov 27, 2006 | 01:33 PM
WS Sick's Avatar
Don't count Speed Pro pistons short, is there better pistons out there, yes, but for the money the durability of a Speed Pro piston is second to none, they are very tough !!!
Speed Pro makes lighter forged pistons made of the same material, just look through their catalog.
What I did for my motor I am working on is I bought the Speed Pro piston, and the Mahle rings.
Old Nov 27, 2006 | 02:42 PM
Thats why i am wondering about there weight.. I am pretty sure the stock ones are 530 something grams...
Whats the LW 2256's as well as the std 2256's.. I doesn't say on summits web site..
Old Nov 27, 2006 | 03:05 PM
LW2256F 30 - 549g.
L2256F 30 - 610g.
