special tools
Old Jun 8, 2011 | 05:47 PM
Shaun 95 camaro's Avatar
special tools
Do I need any special tools for doing a head gasket job on my 95 camaro lt1 or is it just typical tools. and how do I adjust the rockers when I get the heads back on.
Old Jun 8, 2011 | 06:53 PM
RamAir95TA's Avatar
Re: special tools
You need a fuel line disconnect tool (if you want to completely remove the lines). Otherwise you don't need it and you can flip the rails up and out of the way. You'll also need a good torque wrench. A search should yield extensive results also.
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
Old Jun 9, 2011 | 01:26 AM
henryz28's Avatar
Re: special tools
The torque wrench will be the most important tool you will need; aside from the knowledge of how to do the job correctly. Search for what needs to be done and what parts should be used.
Louey
Pacific
Oct 1, 2015 12:37 AM
CARiD
Sep 30, 2015 05:44 AM
Sep 17, 2015 11:53 AM
Sep 11, 2015 09:44 AM
