Find me an oil pump!
Old Jun 7, 2011 | 01:44 AM
19z28camaro02's Avatar
Arrow Find me an oil pump!
I've read previous threads and am going to stay away from the grenades. I'm trying to find the good part number for a Melling Select pump. I believe the one I want is 10550. (Do I want to swap the spring as well?) If that is incorrect, please share your wisdom! I'm also going to need to know the correct number for the pick-up tube as well. Help me quick, I want it out this weekend!
Old Jun 7, 2011 | 04:26 AM
RamAir95TA's Avatar
Re: Find me an oil pump!
What pan, what engine, what modifications, what vehicle intentions?
Old Jun 7, 2011 | 07:39 AM
To replace stock:
Melling Select 10554 pump (std vol, 3/4" inlet. Should come with Melling IS-55E shaft with metal coupler and additional 70# pink spring-use it).
GM pickup tube, 12550042 (3/4").
GM oil pump drive gear 1103868 (if needed).
Old Jun 7, 2011 | 09:29 AM
Shoesbox, as always, thank you.
Old Jun 8, 2011 | 11:04 AM
It did not come with a spring. Is there a part number so I can get it somewhere else?
Old Jun 8, 2011 | 12:11 PM
bw_hunter's Avatar
GM part number 13848911. It's a white colored one from the General.
Summit Racing has it for $4 so I guess a dealer might be persuaded to sell it to you for $20.
Old Jun 8, 2011 | 03:52 PM
Everyone tells me it comes with two springs. The Melling pink spring is the same as the GM white spring.
Old Jun 9, 2011 | 02:10 AM
MachinistOne's Avatar
You have no need for a high volume pump(10550), it's just wasting horsepower pumping extra oil that bypasses right back into the pan. Just use a standard series M-55A pump which has the high pressure spring already installed - Melling is back to using the heavy duty casting on those pumps and has been for over a year.
That being said, Shoebox is right about that 10554 if you're dead set on the select series....but get the high pressure spring which should have been in the box. I have not seen the pink in a long time, it's green and yellow now IIRC - and being that they have changed the springs around I would be apprehensive using the GM spring as a substitute unless you already have someone who can attest that it will drop in and raise the pressure properly.
Old Jun 9, 2011 | 05:42 AM
Guest47904's Avatar
Guest
According to the page on Summit, http://www.summitracing.com/parts/MEL-10554/
the high pressure spring is NOT included.
When you weld the pick-up on, don't forget to leave the guts out.
Old Jun 9, 2011 | 06:05 AM
95zsean's Avatar
This is what I used after HOURS of research. It's 10% higher volume, high pressure, with a bolt on pick-up, and has a anti cavitation option.
https://www.camaroz28.com/forums/pic...pictureid=3839
Old Jun 9, 2011 | 06:57 AM
I don't know how many people have said it came with two springs. I guess things may have changed.
Old Jun 9, 2011 | 08:33 AM
RamAir95TA's Avatar
2 years ago, I bought the 10554 and it came with the high pressure spring installed.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jessie4tin
Jan 7, 2015 08:53 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Captain Kirk
Jul 26, 2002 06:39 PM
