Sparkplug wire routing
Old Jan 17, 2006 | 05:16 PM
92/95TransAm's Avatar
i was just wondering if anyone has a clever way to route spark plug wires. i just got taylor 8.2 mm wires today. they are stock lengths. my stock placement looms are all broken and not intact. i still have my stock manifolds but not for long. headers are sitting in my room waiting for a y pipe. but i need to get these wires on so i can stop my old ones from arcing all over the place.
Old Jan 17, 2006 | 05:36 PM
atljar's Avatar
Re: Sparkplug wire routing
On the drivers side tuck them between the block and the block heat shield.
On the passenger side run them behind the dip stick for 6/8. Run all the wires BEHIND the accessory bracket (tight fit, but they will go) and then right into the opti.
Old Jan 17, 2006 | 05:37 PM
zjet's Avatar
the pass side i did between the block and the alumiun plate that holds the ps pump and stuff,the drivers i did stock.i have 8.5 msd wires.i like pass side that way it easier to change wires and not have to remove the ps pump and alt.and they run right along side the block
sorry atljar i was posting when you where,same idea though
Old Jan 17, 2006 | 06:09 PM
i dont think i have a block heat sheild. if i did where is it located?
Old Jan 17, 2006 | 09:36 PM
OBE1 95Z28's Avatar
It a metal channel about 1-1.5" wide and 18"+ long that bolts to the block just under the exhaust manifold.
Old Jan 17, 2006 | 11:48 PM
revtime's Avatar
Those things are a PITA, I took em off and threw em away.
I have MSD 8.5s as well and I routed the driver side up and over the valve cover for 5 and 7 (I have hooker LTs) 1 and 3 I routed in the stock configuration. Passenger side I routed number 2 in the stock location behind the alternator, 4, 6 and 8 I routed low through the alt bracket but I covered the wires in convoluted tubing where they went through the bracket to keep them from damage from rubbing on the bracket.
27k on the wires now and never burnt one.
Oh yeah, zip ties are good, buy a bunch.
Nov 18, 2023 07:21 PM
thenewkid
Apr 12, 2015 07:42 PM
Lt4Z2897
Mar 26, 2015 03:02 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
