spark retard wot
Old Jul 16, 2004 | 12:37 PM
speedcrazy's Avatar
spark retard wot
i seem to peak sometimes at 9 or so degrees of spark retard only really at or near wot and higher rpms. just wondering the possibilities that would only cause this at wot. most likely ignition trouble?
i know if im pulling 9 degrees im loosing a bit of power.
also not all the time but sometimes when the car is really warm or its warm outside it will miss in higher rpm's too.
please help me out and give me some ideas of things i can check.
Old Jul 16, 2004 | 02:19 PM
95z6spd's Avatar
a common problem is the coil wire. I would first replace that or atleast pull it out and check it. My car was doing the same thing and i knew it was something in the ignition. Instead of replacing one thing at a time i put new plugs (bosch +4's, new wires accel hi temps, accel 300+ racing ignition with their coil) that eliminated my high rpm problem and the car started runing like a beast. I later installed a LT4 knock module as it is less sensitive to knock
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
SEOJustin
Sep 24, 2015 04:39 PM
